Today I checked all frequencies between 1200 and 2200 MHz
are bad
Example with I fed from RF3 frequency generator
In the example -20DB
The signal is low -50DB
Up to frequency 1200 and above frequency 2210
The device works perfectly
I don't have another spectrum analyzer
for this moment i give up
When I ordered the filters
I ordered 3 types
the 836.5MHZ B122
and 2 types of 1842.5MHZ
the
[50pcs] B69813-N1847-X475 PCN RX Filter 1842MHz SMDIt was really rubbish
installed was no signal at all frequencies
that I installed the
B39182-B4139-U410 1842.5MHz SAW Filter 50 Ohm SMDAll frequencies up to 1200 and above 2200 were perfectly fine again.
With the new filter of 1842.5 The Internal loop test
range of 10 MHz and 1200MHz perfect
range of 2205-2700MHz perfect
succeeded
Better than the original.The frequency group 1200 to 2200 is really bad
the fm modulation calibration pass
But still failed L1 CO PRO LEVEL CAL
The level is too low. Check the if signal connection
