Author Topic: Tektronix 2225 oscilloscope showing only two Dots instead of two lines  (Read 8458 times)
Offline megadethTopic starter
  • Country: eg
Hi everyone,
Just got a secondhand Tektronix 2225 oscilloscope as my first oscilloscope, when I switch it on only showing two dots on the screen which representing the two channels, they are responsive to vertical and horizontal position knobs, unfortunately, I got the oscilloscope without the probes  :-// so I will not be able to test if these dots are responding to the measured waves unless I buy the probes, could anyone advise how to start troubleshooting this problem.
Thanks in advance.
Offline Circlotron
Is the SEC/DIV knob set to XY? That will produce a stationary dot.
The following users thanked this post: megadeth
  • Country: eg
No, it is not on XY, I will take a photo to it once I reach home and posted here.
Thanks,
Offline David Hess
  • DavidH
Having the beam unblanked but the sweep stuck often means that the sweep generator has failed.  Sometimes it is as easy as the JFET buffer being bad.
Offline CaptDon
  • Country: is
Try the AUTO TRIG mode. If no input then the thing probably isn't even triggered!!
  • Country: eg
OMG, Thanks a lot i got it work perfectly now.
Appreciate your help, and thanks to everyone who tried to help.
« Last Edit: March 14, 2024, 02:47:50 pm by megadeth »
The following users thanked this post: Circlotron
Offline TimFox
"Auto trigger" means that the CRO horizontal sweep waits for a finite time without receiving a trigger, and then triggers itself regardless of the trigger level setting.
Offline artag
Just poke a bit of wire (or a resistor) into the centre of the input BNCs. Your fingers will pick up lots of 50/60Hz mains noise and give you a display.
Offline donlisms
Or maybe not...
BNC connectors actually have specs and precision tolerances and that sort of thing.  It's generally a bad idea to risk loosening up the contacts with a random piece of wire, if you want to keep your connections in good shape forever.
(Not that I would ever do that...  :-) )
Offline David Hess
  • DavidH
On vintage oscilloscopes the BNC for channel 1 is often worn out through normal use anyway.
There is nothing special about the BNCs on a 50 MHz oscilloscope, so they can be easily replaced.  Check out the wire dressing going to the BNCs on the 50 MHz 2225, or any of the 100 MHz 22xx oscilloscopes.  It is usually a low value air wired 1/8 watt carbon composition resistor.
« Last Edit: March 15, 2024, 05:35:47 pm by David Hess »
