Author Topic: Brüel & Kjær 2801 Microphone Power Supply Schematics  (Read 1906 times)
Offline SmokyTopic starter
« on: January 08, 2024, 05:13:07 pm »
I'm hoping that someone might have a copy of the Brüel & Kjær 2801 Microphone Power Supply schematics.
I put together the 2801 microphone power supply, the 2615 cathode follower microphone pre-amplifier, and the 4134 microphone for a test.
I'm measuring 14.5v of DC after the internal 4uF blocking capacitor at the direct output. I measure 62v of DC before the blocking capacitor (signal path from the microphone).
When I speak from a distance into the microphone, I do get between 0-10mV of AC at the output.
Offline timop
Re: Brüel & Kjær 2801 Microphone Power Supply Schematics
« Reply #1 on: July 15, 2024, 09:26:11 pm »
I have a service manual for the B&K 2803 two channel power supply, dated from 1967. The circuit might be quite similar to the 2801 (block diagram attached).
If you're still interested, I can scan it and make it available after returning from my summer holidays in a couple of weeks.
BR, Timo
The following users thanked this post: Smoky
« Reply #2 on: July 17, 2024, 04:37:28 am »
Thank you very much :-+ The 2803 is also "tube" driven so it should be very similar to the 2801. No hurry either, I won't be digging into any electronics-related stuff for a few more months.
Offline timop
« Reply #3 on: July 30, 2024, 12:03:15 pm »
Here's the B&K 2803 Two Channel Power Supply service manual + schematic. Enjoy!
The following users thanked this post: Smoky, Zoli, RAPo
