Author Topic: hameg hm1507-3 osiloscope  (Read 3845 times)
Offline icomdealer.ir@gmail.comTopic starter
  • Country: ir
« on: June 06, 2017, 06:01:52 pm »
Hello.
i have a hameg 1507-3 (150 mhz ) osiloscope , there is some thing wrong with it . it some times works fine but mostly after turning on the oscope , it begins to spark and scintillation ( you can hear the sound in the short clip) . what is the problem ? can anyone help
you can see the problem in this clip  :   https://youtu.be/sGwUKPu3Xho
regards
  • Country: ir
Re: hameg hm1507-3 osiloscope
« Reply #1 on: June 07, 2017, 08:10:27 pm »
no idea ?
Offline grumpydoc
« Reply #2 on: June 07, 2017, 08:20:16 pm »
The EHT is arcing somewhere, open it up and look for obvious signs of carbonisation, loose EHT connector etc.
Turning it on in a darkened room with the covers off may enable you to see where the problem is.
However, be careful - the anode voltage in a 'scope is anything up to 20kV, don't probe, prod or touch if you are unsure what you are doing, and remember that high voltages might be present even with the power turned off.
  • Country: ir
« Reply #3 on: June 23, 2017, 08:02:19 pm »
Hello . i opened its cover in a dark room . the spraks are from a component that is similar to  voltage multipier package in stungun (i attach the picture)  it may be  eht unit as you said .the sparks seem to be inside the component and on its surface .also at the buttom of smps board there was a effect of spark , at the place of connection between that component wire and the board.
should i replace that component or it will be repaired ?
may the problem be some where else and cause that component to spark ?
please help
regards
Offline grumpydoc
« Reply #4 on: June 23, 2017, 09:20:12 pm »
Yes, that is the EHT multiplier.
It will need replacing by the sound of it - the difficulty is normally getting hold of the right part.
  • Country: ir
« Reply #5 on: June 23, 2017, 09:36:13 pm »
Tnx for your answer . How can i get a new one to replace ?
Offline tronde
  • Country: no
« Reply #6 on: June 24, 2017, 01:27:39 am »
I understand that SKY Messtechnik in Germany is service partner for older Hameg equipment. They stock spare parts and understand English.
http://www.sky-messtechnik.de/kontakt-sky-messtechnik
  • Country: ir
« Reply #7 on: June 24, 2017, 04:01:58 am »
ok. tnx for your help . i will contact them.
