Author Topic: Safety Capacitor question  (Read 3369 times)
Offline BrokenYugo
Re: Safety Capacitor question
« Reply #25 on: November 19, 2021, 02:12:26 am »
I assume you know it's generally safe to round to modern values.
C3, I'd probably use .022, this couples audio into the first amplifier stage, higher value=stronger bass, so may as well use the biggest the engineers saw fit to use.
C5 I think is a feedback capacitor? Probably another .022, remember that anywhere they used paper caps isn't terribly critical.
33 and 47 (or better yet 68, old electrolytic caps were usually toleranced at -20%, +80%, so you can safely go up a bit) for the B+ filters, also go up on the voltage rating as often old stuff ran near the limit. Higher voltage rating also often means a larger, higher ripple rating, cooler running, longer life part. It is possible to get into trouble there with considerably smaller modern capacitors running hot.
Offline ttx450Topic starter
« Reply #26 on: November 20, 2021, 02:30:06 am »
Hi, yes.  Thanks for explaining how the caps influence the sound. The RCA service repair book (I don't have)has upgrade and modifications.  I wish I had a copy of that.
So upping the 2nd cap is safe?  Newest schematic version is 50uf.  See what I can find in 68ish going to order some stuff soon.
Thanks for the info.
« Last Edit: November 20, 2021, 02:33:25 am by ttx450 »
