I am looking for a wire to chassis connector. The chassis could be the steel frame of a PC enclosure for example, or some steel plate protrusion in the boot of a car for another example.
Of course I can use a crocodile connector but vibrations will knock it off, I need something much more secure.
I do not want to dril a hole on the chassis.
I am imagining a g-clamp style of small connector (rather than a crocodile one) with a screw that secures the g-clamp onto the plate, and the same screw also secures the wire.
Is there something like that and what is it called?
