Definitly a hole, this is a 5 volts regulator ?? you can check icl 7107 datasheets voltmeter ic, pretty common, you will be able to find the resistor value. too test the display put regulated 5 volt on c13 side going to the busted regulator pins, youll see if the chips and the leds are still good.
Theses regulators normally go up to 40volts
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
so something bad really happened.
Do you have an complete schematic link ??
The first op thread about r38
Normally this psu has a floating regulator section over the main supply, the common point pass thru R38 ?? but i find it slighlty strange.
I begin to doubt they arent well designed in some way if you have them all failing at some point.
