Author Topic: Speaker Grill construction - Cerwin Vega AT-12  (Read 3910 times)
Offline Jay_Diddy_BTopic starter
« on: August 23, 2018, 10:40:15 pm »
This project is more woodworking than electronics. I am going to share the construction of a pair of speaker grills for a vintage Cerwin Vega AT-12 loudspeakers. This shows How I did for the Cerwin Vega's, the techniques should work for other brands.
I have bought two pairs of CV speakers, AT-10 and AT-12. The AT-10 speakers came with grills, the AT-12 did not. I used the AT-10 grill as a guide for fabricating the new grills.
I cut the new grill frames from 3/4" MDF board. The outside dimensions are 14 x 26 inches.
There is a 45 degree bevel on the front side:
And recess for the bass driver on the rear side:
Here is a picture of the grill attach pins:
I found similar pins at two places:
https://www.parts-express.com/parts-express-heavy-duty-speaker-grill-guides-12-pair--260-367
And
https://qcomponents.ca/McBride-GRILL-PIN-LARGE.html
I bought these pins:
To make these pins work, I added some spacer washers cut from 1/4" plywood.
To be continued …
Regards,
Jay_Diddy_B
« Last Edit: August 23, 2018, 10:45:06 pm by Jay_Diddy_B »
Re: Speaker Grill construction - Cerwin Vega AT-12
« Reply #1 on: August 23, 2018, 10:48:34 pm »
Hi group,
The construction continued by staining the frames black:
I used Unicorn Spit from the Home Hardware store. (Why use snake oil on an audiophile project, if you can get Unicorn Spit?)
I then covered the frames with black speaker cloth that I bought from Fabricland.
Here is a picture of the finished project:
Regards,
Jay_Diddy_B
« Last Edit: August 23, 2018, 10:56:39 pm by Jay_Diddy_B »
Offline oventech
« Reply #2 on: August 23, 2018, 11:20:09 pm »
Nice work. Turned out really good. Never heard of "Unicorn Spit" before. Have to keep this thread in mind if i have to redo (make) a new speaker grille.  I know some guys on AudioKarma.org  would enjoy seeing the result.
Offline salvagedcircuitry
  • Electrical Engineer | Hobbyist | Camera Enthusiast
    • salvagedcircuitry
« Reply #3 on: August 24, 2018, 12:02:29 am »
Nice job! My neighbor threw out a pair of AT-12's about 2 years ago. The speaker surrounds were completely rotted out. I was going to fix them but I simply did not have the space to keep them, so I put them up on craigslist free. Crazy.
