Thanks for the pic, that's the chip. I hadn't considered the possibility of a custom chip, I have searched the VW forums and while there are lots of threads about problems with clusters using this chip, there is no useful info. There are whispers about it being a Programmable System on a Chip - PSOC but even VW's volume wouldn't seem to amortize a full custom design, more like a semi custom arrangement of function blocks around a core. Big NRE up front but easily justified for a couple hundred thousand units.
And there were comments about professional shops that repair these clusters being able to talk to that chip, which indicates that they had sort of cracked it. I'm not interested in reverse engineering it, just enough to determine if the problem lies elsewhere. The tach and speedo are stepper motors, and the drivers are inside the chip.
I was hoping to not have to start from zero on this, I do have a benchtop lab at home, fast scopes, logic analyzers etc, but not really suited to mobile applications. Perhaps time to buy a Picoscope.
Erik
