Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
old B&W crt
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: old B&W crt (Read 688 times)
pop982
Newbie
Country:
old B&W crt
on:
March 22, 2021, 01:41:28 pm »
Hi i got a small "gern" crt and no matter how much i adjust the v-hold it doesn't look any better than in the picture.
I can't for the life of me find any info about this tv or any kind of manual.
Any suggestions for any adjustments i could make?
Logged
CaptDon
Super Contributor
Country:
Re: old B&W crt
Reply #1 on:
March 22, 2021, 01:47:00 pm »
That is not a vertical hold problem, it is a vertical size or vertical linearity problem. There may be adjustments available on the circuit board. There may also be an out of tolerance resistor or capacitor at the real root of the problem.
Logged
pop982
perieanuo
Frequent Contributor
Country:
Re: old B&W crt
Reply #2 on:
March 22, 2021, 02:13:35 pm »
find on that pcb your vertical deflection chip tracing the deflection coil, then here you have the datasheet/schematic for V deflection, then you can trace why the V isn't ok
you're lucky, that's the simpliest in the book
Logged
pop982
jdragoset
Regular Contributor
Country:
Re: old B&W crt
Reply #3 on:
March 22, 2021, 02:42:25 pm »
Vertical foldover.
Had a Toshiba that did that, re-soldering the pins on the vertical amplifier chip fixed it.
When it did it again, put #26 Ga. insulated wires from each pin to the foil pattern.
Logged
pop982
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
old B&W crt
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
