Loading [MathJax]/extensions/Safe.js
Author Topic: Doulbe-sided codes on Tantulum capacitors  (Read 1697 times)
Offline BobertsawesomeTopic starter
« on: August 19, 2020, 05:30:00 am »
Hi there,
This one stumped me as I have never seen this marking method before, nor could I find info on the web regarding a double-sided code marking.
1st side 104-e5m , 2nd side 720-rac (same capacitor)
I assume it is 100nf, but not sure what or how to find the voltage rating. Included here are the photos for relevance:
Just a hobbyist and evolving voltnut
Offline garrettm
Re: Doulbe-sided codes on Tantulum capacitors
« Reply #1 on: August 19, 2020, 06:20:03 am »
I believe that is a ceramic capacitor, not a tantalum. Tants have a polarity marking which this part does not have.
100 nF sounds right: 104 => 10*10^4 pF = 10*10^-8 F = 100 nF.
As to the voltage rating, good question. I couldn't find anything for e5m or RAC as a part name. Those also don't line up with the voltage/tolerance codes either.
Regardless, what is the measured voltage in circuit? Assuming it was derated 20-50%, that at least gives you a start.
Are you replacing a bad part or something else?
« Reply #3 on: August 19, 2020, 07:19:03 am »
You are definitely correct, it threw me off considering the rest of the caps are tants. The circuit is fine, needed some minimal repairs due to degradation over 25+ years. Figured I'd recap at the time too. I suppose I'll just check the voltage to the cap, but was wondering more in the long run what the dual codes meant.
