Author Topic: Cautionary tale on microwave oven repair  (Read 14819 times)
Offline GnatGoSplatTopic starter
« on: October 23, 2012, 09:08:00 pm »
We all know it could happen, but until I found this article, I'd never read about it actually happening to someone.
http://worthcounty.walb.com/news/news/60220-update-deadly-microwave-was-not-plugged
Shawn
Offline nixxon
  • Country: no
Re: Cautionary tale on microwave oven repair
« Reply #1 on: October 23, 2012, 09:30:48 pm »
It cannot be stressed enough: Never fiddle with high voltage circuits on an empty stomach
Offline nicknails
« Reply #2 on: October 23, 2012, 11:04:12 pm »
Maybe I'm just morbid, but I snickered a little at this:
"Family members say they are shocked by the tragic accident, and Roddy will be missed."
Offline PbFoot
« Reply #3 on: October 23, 2012, 11:25:29 pm »
I don't know if this guy was qualified or not, but I will add - don't open equipment, especially high voltage equipment if you do not know exactly what you are doing.
-PbFoot
Online tom66
« Reply #4 on: October 23, 2012, 11:32:31 pm »
I don't understand though how you could walk into a room after being electrocuted, then collapse? Perhaps he had a pre-existing condition, like a heart problem.
Either way it's another reason I don't touch (work on) microwaves if I can avoid them. The cap is supposed to have a bleeder resistor but I don't put any trust in it, especially in cheaper units.
Offline N2IXK
« Reply #5 on: October 24, 2012, 12:24:16 am »
The bleeder resistor is often inside the capacitor, and it is often burned open.
Those are pretty big oil-filled caps, and can hold a charge for weeks if the bleeder is open. Microwaves are VERY dangerous to work on if you are unfamiliar with high voltage circuitry.
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline nitro2k01
« Reply #6 on: October 24, 2012, 01:44:09 am »
Yeah, most likely heart problem. After a cardiac arrest, you probably have 1-2 seconds before you black out.
« Reply #7 on: October 24, 2012, 02:07:14 pm »
Yeah, I've always felt uncomfortable working on microwaves, even though they should be perfectly safe if unplugged and capacitor discharged.  I've only had to do it a couple times in the past, and I recall going to the trouble to wear welding gloves just to discharge the cap, first with 2 flathead screwdrivers and a resistor connected between them, then I'd check the cap for voltage using my multimeter, if volts were low but not zero, I'd short across with the screwdriver until zero and then place a short across it with alligator clips for the duration of my working on it.
I had to get into my Panasonic inverter microwave to repair some burnt wiring at the door switch, and was happy to see that inverter microwaves don't have that big capacitor.  There are a couple of non-polarized poly-looking capacitors on the inverter board which I checked for stored charge and shorted across just for safety's sake, but they didn't hold any charge with the unit off.  The entire board was very small and light-weight with what seemed like a much lower component count than conventional microwaves, it seems like a pretty nice improvement in technology.
Shawn
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #8 on: October 24, 2012, 02:29:53 pm »
 For what they cost it's not worth it, when ours went pop, I put it in the bin for land fill, after cutting plug off.
no one would or will tell me how to delete this account
Offline IanB
« Reply #9 on: October 24, 2012, 02:40:36 pm »
You can drop dead up to a day after receiving an electric shock. If you ever get an electric shock bad enough to make you black out of feel dizzy you need to go straight to hospital and get checked out. Death by electric shock can result from a disturbance to the heart rhythm that may have a delayed action.
« Reply #10 on: October 24, 2012, 03:06:24 pm »
The standalone ones are quite inexpensive to the point of being disposable, but over-the-range models are still quite expensive.  They're typically about US$200-300 here.
Shawn
Offline M0BSW
« Reply #11 on: October 24, 2012, 03:30:32 pm »
OK Shawn didn't realise it was that type , we have them built into the ovens over here in the  UK , I still wouldn't touch it, I'd get someone in , ours  was a stand alone one about £25.00 UK not sure what that is in dollars.Guessing about $35.00 just goes to show these things are always willing to bite you , or kill you in this poor mans case.
Paul
« Last Edit: October 24, 2012, 03:36:14 pm by M0BSW »
Offline G7PSK
  • It is hot until proved not.
« Reply #12 on: October 24, 2012, 03:37:29 pm »
A piece of wire with a croc clip each end is the best thing to discharge these caps. Also leave the wire in place while working on the unit, I have had oil filled capacitors charge themselves up from from background emf, I had one from an old TV when a kid ad at school I would hold it by the brass studs at each ends to show it was safe then wave it near a florescent tube and produce a big fat spark from it.
« Reply #13 on: October 24, 2012, 03:43:20 pm »
I am wary of that side, but most faults are in the door switches losing alignment or the magnetron or diode dying. Only ever had one cap go short circuit.
Offline c4757p
  • adieu
« Reply #14 on: October 24, 2012, 03:45:44 pm »
Wow. I've had capacitors appear to recharge themselves - when you discharge them quickly, the internal resistance means they discharge more from the points directly near the electrodes, and then when you stop, the charges that were far from the electrodes redistribute. But I've never heard of one charging itself from background EMF. That must be one low-leakage capacitor.
Offline M0BSW
« Reply #15 on: October 24, 2012, 04:00:33 pm »
,  I just looked at mine there's a big sticker on it , DO NOT OPEN NO servisble user parts,lethal voltage, good enough for me.
« Reply #16 on: October 24, 2012, 04:15:44 pm »
Oh, I don't think that man's microwave was an over-the-range type since it's a big project just taking down one of those.  Mine were regular standalone types as well, though the wife does insist that our next one be a pricey over-the-range model.  I just mentioned that to point out that not all are disposable cheap throwaways.  £25.00 is about $40 US which I believe is not uncommon during holiday sales, but year-round normal price for the cheapest Chinese microwaves are about $50 or £31.00.  My current Panasonic inverter was about US$125 or £78.00, one of the pricier standalones.
Working on a microwave is safe if proper care is taken to discharge the big capacitor, but until it's discharged, it's definitely dangerous enough that I can understand the wisdom in just chucking it if it's a cheap disposable one.
Shawn
« Reply #17 on: October 24, 2012, 04:21:22 pm »
That would be a doorknob ceramic cap. In a dry climate they can hold charge for decades.
Offline M0BSW
« Reply #18 on: October 24, 2012, 05:04:06 pm »
There quite cheap over here, supermarkets sell them discount sellers sell them the competition is fierce, we usually get two years out of them then it's bye bye  I just look in a electrical discount store are selling a chinese one for £19.00 UK, in all colours, it's not going to last but for £19.00 uk, if it lasted a year that's fine, only time I get near high voltage is when I'm doing something on one of my tube Ham radio transceivers, then I use 1 megaohm bleeder resistors on the cap left on there overnight, in fact I leave them on the caps any time one of my hands have to be inside, never put both in. otherwise its all low 9/12 volts.
Offline Zero999
  • 0999
« Reply #19 on: October 24, 2012, 10:42:35 pm »
You're right but your explanation is completely wrong. The internal resistance of a decent capacitor is low enough to ensure it'll discharge completely. The reason why some capacitors appear to recharge is down to dielectric absorption.
http://en.wikipedia.org/wiki/Dielectric_absorption
I believe that oil filled capacitors used in microwaves have a fairly low dielectric absorption so any recharge shouldn't be bad enough to cause a hazard.
Online tom66
« Reply #20 on: October 24, 2012, 10:45:00 pm »
The typical microwave oven capacitor is sub 2µF - typically paper or oil capacitor? Is there a reason electrolytic caps aren't used - too high of a voltage?
« Reply #21 on: October 25, 2012, 04:33:18 am »
AC voltage across the capacitor. It is used in a voltage doubler directly across the 1000V secondary of the transformer. It has the full magnetron current flowing through it at all times, and has to withstand the full peak to peak voltage of the unloaded transformer during the magnetron warmup time. Thus 2800VDC rating minimum.
Offline Sionyn
« Reply #22 on: October 25, 2012, 09:14:20 am »
he obviously had no idea what he was doing let alone any chance of repairing it
shame
eecs guy
Offline HackedFridgeMagnet
« Reply #23 on: October 25, 2012, 01:41:09 pm »
How to pretend you're linking your news story to real information.
<span style="text-decoration: underline;">Here is the full press release from the Sylvester Police Department</span>
jucole
  • Guest
« Reply #24 on: October 25, 2012, 05:13:26 pm »
Some very unfortunate people are actually born with heart defects that don't get detected until their later years or before; but by then it's sometimes too late.
