I have a garage gate fob (DKS brand) that opens 2 gates, one of the buttons (micro tactile switch) isn't working. I gently pried off the non-functioning button and soldered on a new one, thinking that would fix it, but no. Could it be something with the soldering job, or is it more likely to be a different problem? The original fobs for the building are about a decade old now, and other people here are having the same issue.
