Author Topic: Can anybody tell me how this transistor opens?  (Read 2500 times)
Offline JGANTopic starter
    • Micro Soldering Supply
« on: November 21, 2015, 03:53:37 am »
I'm trying to fix a dead computer board. It is missing this "ALL_SYS_PWRGD" signal, which comes out of this transistor Q8150. I can't find the datasheet for the transistor, but what is confusing me are all the S0 state rails that go into Q8150. The computer should be in the S5 state if it is off, but then how is "ALL_SYS_PWRGD" created? Are all these "Q2" "Q3" "Q4" transistors within not necessary for current to flow through to the output of Q8150?
Basically, is this some sort of transistor where only one source is necessary for the gate to open?
Offline rs20
Re: Can anybody tell me how this transistor opens?
« Reply #1 on: November 21, 2015, 04:11:33 am »
Q1 is a N-type MOSFET. Q2, Q3, Q4 are NPN transistors. Google for the proper terminology for the three legs for a MOSFET (gate, drain, source) and NPN/PNP transistors (collecter, base, emitter), "output" is vague.
If Q2, Q3, Q4 are all turned on, by bringing their bases high enough, the gate of Q1 (same net as the collector of Q2) is pulled down to ground, Q1 is turned off, and ALL_SYS_PWRGD is open-circuit, presumably pulled high by a pull-up resistor not shown in the schematic.
If any of Q2, Q3, or Q4 are off, its gate of Q1 goes high (pulled up by R8156), Q1 is turned on and ALL_SYS_PWRGD is pulled to ground (0 V).
To answer your question, current flowing into the drain of Q1 flows out the source. Q2, Q3 or Q4 being off, combined with PP3V3_S5 being high, enables this current to flow.
Keep in mind that signals are sometimes active-low, i.e. a net labelled "S5" might be low if the S5 state is active, high otherwise. This is sometimes denoted by a line over the name, or a "#" or "!". This is certainly true of the PS_ON# signal of ATX PSUs, which you must pull down to ground if you want the PSU to turn on.
« Reply #2 on: November 21, 2015, 04:33:33 am »
Perfect! Answered my question completely and also made me learn BJT transistors. Thanks!!
« Last Edit: November 21, 2015, 04:40:33 am by JGAN »
