Author Topic: Fluke 87 - DC reading very slow  (Read 2720 times)
Offline chrsmTopic starter
« on: November 20, 2019, 05:26:59 pm »
We have an old Fluke 87 which show DC reading very slow. If we e.g. measure a 1,5v battery then it takes about 5 sec. to stabilize the reading. AC reading works fine.
We have tried to remove the varistors VR1 and VR1 and the surge protector E1 without any change.
Any ideas ?
« Last Edit: November 21, 2019, 06:59:49 pm by chrsm »
Offline Axtman
Re: Fluke 87 - DC reading very slow
« Reply #1 on: November 20, 2019, 07:19:55 pm »
Which version? Fluke 87, 87 iii, 87 iv or 87 v?
« Reply #2 on: November 21, 2019, 10:14:23 am »
The first one Fluke 87 without any version
Offline mzacharias
« Reply #3 on: November 21, 2019, 05:59:14 pm »
Measure the 87's input impedance and confirm about 10-11 MegOhm.
I have an 83III that for some reason the input impedance is is around 14 MegOhm, and is slow to settle.
(Actually that 83III mainboard is retired for now for this reason)
Offline retiredcaps
« Reply #4 on: November 21, 2019, 08:39:40 pm »
Show a 7 second video of the above.
What happens if you measure a 12V DC power supply instead of an AA cell?
« Reply #5 on: November 21, 2019, 10:20:41 pm »
With the Fluke set to DC reading it has a imput impedans of around 10MOhm
Offline Electro Detective
« Reply #6 on: November 21, 2019, 10:58:30 pm »
I go for the usual suspects first:
Dirty sockets, crusty lead plugs,
black smudge cross contamination on switch selector tracks,
cooked input components
or intermittent combo of the above   |O
« Reply #7 on: November 21, 2019, 11:08:20 pm »
I have uploaded 2 videos to google that show reading of an 1,5V AA cell and 12V power supply. The reading of the 1,5V AA cell is actually to high
https://photos.app.goo.gl/SNW6oj6LpGMe2zfv6
Online The Soulman
  • The sky is the limit!
« Reply #8 on: November 22, 2019, 12:37:29 am »
Do you have another meter so that you could measure the voltage
simultaneous with the faulty fluke?
Just to make sure the fluke isn't affecting the source in anyway?
If only dc voltage is affected (and dc current is fine?) it might be as simple as a bad
contact on the range switch.
btw, How did you conclude ac voltage is fine, just stuck it an outlet?
Offline retiredcaps
« Reply #9 on: November 22, 2019, 01:23:22 am »
There is definitely something wrong with your meter as shown by the video.  It should take the 87 less than 1.5 seconds to provide a stable reading.
Regarding the input impedance, see my pictures at
https://www.eevblog.com/forum/repair/fluke-87-i-repair/msg390462/#msg390462
With the 87 set to mV, input impedance should be exactly 10M ohm.  At DCV, it should read exactly 11.11M ohm.
If you already removed the varistors and spark gap, leave them out for now.  Check your 87 PTC.  It should be around 1.5k ohm.
With Electro Detective's suggestion, see
http://mrmodemhead.com/blog/all-posts/
for several Fluke related repairs that involved giving the entire pcb an IPA bath, cleaning rotary switch tracks, removing carbon buildup, etc.  Lots of good case studies and suggestions to try.
http://mrmodemhead.com/blog/ideal-carbon-footprint/
« Last Edit: November 22, 2019, 01:33:26 am by retiredcaps »
Offline retiredcaps
« Reply #10 on: November 22, 2019, 01:24:50 am »
At Mark, I have a working 83 III if you would like to make some comparison readings.  If yes, start a new thread and I will try to help you pinpoint what is wrong with your 83 III pcb.
Offline retiredcaps
« Reply #11 on: November 22, 2019, 01:55:08 am »
BTW, all the varistors and spark gap should measure 0L resistance.
Offline mzacharias
« Reply #12 on: November 22, 2019, 10:06:52 pm »
Well, I already robbed the LCD from that one. Works fine in an original 83, by the way, just the digits are larger.
« Reply #13 on: November 23, 2019, 02:07:53 pm »
Yes I have another Fluke 83 III that I can use for messurement.
I have used a tone generator and set it to 5V AC, and that works fine.
« Reply #14 on: November 23, 2019, 06:50:23 pm »
I have made 2 videos. One with DC reading, the impedance is round 10,3Mohm raising to 10,6Mohm. And another video with mV reading where it is more stable around 10,11M ohm.
About the PTC it is very strange. When I measured the first time it started to show 1,25k ohm and dropped slowly to 1,174k ohm. When I read it a second time it is stabile around 1,174k ohm. The PTC are unmounted from the PBC.
https://photos.app.goo.gl/wMYbye3VsYL41L8C7
« Reply #15 on: November 23, 2019, 09:39:54 pm »
Problem solved
It was some "carbon dust" on the PBC, near the Z1, that caused the problem. After mechanical removing the "dust" the reading is stabilize within 1 sec.
Thanks to everyone and specially retiredcaps that mention the carbon problem .
« Last Edit: November 23, 2019, 10:49:13 pm by chrsm »
Offline retiredcaps
« Reply #16 on: November 23, 2019, 09:51:56 pm »
Glad you got it fixed.
Is your input impedance now a solid 11.11M ohm for DCV and 10.00M ohm for mVDC?
The following users thanked this post: chrsm
« Reply #17 on: November 23, 2019, 10:48:40 pm »
Yes they are - thanks
