I snagged a cheap 87V off Ebay. The meter is perfect, except the screen is pretty scratched and scuffed up.
A combination of deep scratches and scuffs mar the screen.
I started using the polish by hand, but it had very little effect. I moved on to a dremel and a polishing wheel. I was careful to keep the screen wet with lubricant and to reapply the polish to the wheel and to the screen.
IMPORTANT! Early on in the process, I pressed the wheel into the screen while there was no lubricant. This left a nasty mark on the screen. My final technique was to hold the dremel by the end and let its own weight apply the pressure.
Here is the finished screen, with all of the scuffs buffed out. Many of the deeper scratches remain. For a full restoration, I think I would need to be more aggressive and sand it with multiple grits before doing the final polish. I believe ModemHead has done this before with success.
