My house in Cape Town, South Africa was built in 1900 and renovated in 1949
The gent who renovated was the City Electrical Engineer. In 1949 they used ungalvanised steel pipes. About 2/3 of them have gone rusty, some areas completely corroded away.
I bought the house as a deceased estate in 1984 and have been replacing the cloth and rubber cable with PVC and/or "Flat twin and earth" or "Surfix" which is also a 3-core cable but with an aluminium shield as well. Its a 230VAC mains and the cable is 2.5mm diameter
In 2020 the electrician replaced the outside earth rod which is a 2 metre x 25mm copper rod, with 2 rods, each 15m apart
At the other end of the house, which is 35m away, I also fitted an "earth mat" to ensure a completely quiet and safe earth.
