Author Topic: BT YouView DTR-T4000 powers off  (Read 5655 times)
Offline perdrixTopic starter
« on: March 03, 2024, 08:20:31 pm »
Powers up normally, then change channels and it powers off.
Is there any hope to repair?   Any common issues.  If it can be repaired that's preferred as I don't want to loose all the HD recordings as I understand the HDD HD data is encrypted such that only that box can play back the recordings :(
Thanks
Offline 807
Re: BT YouView DTR-T4000 powers off
« Reply #1 on: March 04, 2024, 03:58:30 pm »
Have you tried a different power supply? Or tried any of the maintenance menu options?
« Reply #2 on: March 04, 2024, 06:00:56 pm »
I tried another power supply as I had one from an earlier Youview box - same problem died pretty sharply.
Never get as far as maintenance menu.
D.
Offline 807
« Reply #3 on: March 05, 2024, 10:58:19 am »
...Never get as far as maintenance menu...
Have you tried pressing the down arrow button for 5 seconds after first powering up the box? I believe the instructions for your box are the same as the T2000 shown here...
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
There are 5 options. 3 of them should keep your recordings...
    1. Software Reset
    2. Factory Reset , keep recordings (recommended)
    3. Factory Reset, delete recordings (if option 2 doesn't resolve your issue)
    4. Internet / USB recovery, keep recordings
    5. Internet / USB recovery , delete recordings
« Last Edit: March 05, 2024, 11:02:11 am by 807 »
« Reply #4 on: March 05, 2024, 12:33:04 pm »
Now it won't stay powered for more than 10s after turn on!  So I think I'm out of luck.
All my soldering kit and meters etc. are in boxes after a house move and even if (as is likely) this is just failed electrolytic caps, I won't be able to replace them for weeks :(.   So to keep domestic peace I've ordered another one from an eBay seller.
D.
