Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Keithly 227 On the bench for repair.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Keithly 227 On the bench for repair. (Read 482 times)
Zenwizard
Regular Contributor
Country:
on:
June 21, 2024, 01:13:37 am »
I have a keithley 227 current source on the bench for repair. It seems to 1/2 way work but it will not output any voltage or current.
I have verified the VS + and - 12 as well as the VD + and - 12 the high voltage is present as well. The odd part is when the meter is in current measure mode it is working and the meter will deflect. When it is in voltage measurement mode there is no meter deflection. Looking forward to adding this one to the lab if I can get it up and running.
Anyone worked on these that might have a good starting point?
Zen
Logged
You Tube Link
- Fixing broken Things
Zenwizard
Regular Contributor
Country:
Re: Keithly 227 On the bench for repair.
Reply #1 on:
June 22, 2024, 01:39:04 pm »
I think I have this one figured out. U205 is getting control and being told what to do but its output is stuck and will not move. Unfortunatly in the 227 U205 is a custom Keithley part and is just labeled IC -76. So there is not a lot that will be able to be done to fix the 227.
Zen
Logged
You Tube Link
tppc
Regular Contributor
Country:
Reply #2 on:
June 22, 2024, 03:03:14 pm »
As per the 227 service manual, U205-IC76 has the same pinout as LM318.
The original Keithley part is probably a selected opamp with better carateristics, but at least for the repair, I believe you can try with a regular LM318.
Regards.
Logged
ch_scr
Frequent Contributor
Country:
Reply #3 on:
August 12, 2024, 05:22:26 pm »
It's already broken, might as well desolder that OPA and try to find a replacement.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
