Author Topic: DJ Mixer, Wrong Voltage, Need Help Identifying Failed Part : Solved  (Read 573 times)
Offline TimmoxTopic starter
Hi all,
Thanks for taking the time to help.
I'm repairing an Allen and Heath XONE 23 DJ mixer that had the wrong power supply connected to it. It runs on 12V but got 24v. I have replaced one of the voltage regulators but am struggling to identify another. It is marked AX06 17. I don't have a schematic but I've deduced it's turning the 12v into a 3.3v rail.
I have marked where it is on the second photo with a red line.
Any help as always will be gratefully received.
Cheers,
« Last Edit: July 30, 2024, 09:12:54 am by Timmox »
Online fzabkar
Re: DJ Mixer, Wrong Voltage, Need Help Identifying Failed Part
« Reply #1 on: July 24, 2024, 03:33:23 pm »
AOZ1280CI, Alpha & Omega, buck regulator, 3V - 26Vin, 1.2A, 1.5MHz, marking AXxx, SOT23-6L:
https://aosmd.com/res/data_sheets/AOZ1280CI.pdf
« Last Edit: July 24, 2024, 03:35:26 pm by fzabkar »
The following users thanked this post: Timmox
« Reply #2 on: July 30, 2024, 09:11:46 am »
@fzabkar
You absolute legend! Thank you so much.
