Author Topic: ID this SMD?  (Read 1038 times)
Online AudiorepairTopic starter
ID this SMD?
« on: January 25, 2022, 10:17:39 am »
this is a synth keyboard scanning circuit with these 5 pin devices connected to each keys' 2 pads, only there is no service manual for this and I don't know what they are, they are normally not present on such key PCB's.
The onboard scanning IC is this one:
https://www.ti.com/lit/ds/schs147j/schs147j.pdf?ts=1643094277130&ref_url=https%253A%252F%252Fwww.google.com%252F
Normally these keyframes are scanned from the CPU side, not locally like this one.
It's a Korg MS20 Mini.
Cheers.
Online xrunner
  • hp>Agilent>Keysight>???
Re: ID this SMD?
« Reply #1 on: January 25, 2022, 12:21:59 pm »
You can check this database - go to "G9"
https://smd.yooneed.one/
I don't know what the last symbol is there, but it might just be a diode or transistor. All five pins might not be used
Offline abdulbadii
Re: ID this SMD?
« Reply #2 on: January 25, 2022, 12:42:06 pm »
G9? so baffled by the last letter
SOT-353    NPN digital transistors
as on https://www.s-manuals.com/smd/g9
Online gamalot
  • Correct my English
    • Youtube
Re: ID this SMD?
« Reply #4 on: January 25, 2022, 01:39:43 pm »
Ah, excellent, thanks to all.
Drew a blank at G9 myself, not in the SMD codebook.
Farnell even have umg9n in stock.
Offline fzabkar
Re: ID this SMD?
« Reply #5 on: January 25, 2022, 05:22:28 pm »
Re: ID this SMD?
« Reply #6 on: January 25, 2022, 06:36:08 pm »
This resource lists it:
http://www.smdmark.com/en-US/search/code?id=g9
Thanks, I did Google another source and that had no G9's either.
I shall make this my primary source in future then.
