The camera makes everything look a little blurry but look at the 'grease' in the corners, especially visible in
top left.
I wanna have an idea of what I am in for when I take this apart because I already have other equipment apart and when I take it apart I want to try to fix all the problems in 1 go, meaning ordering capacitors and leaving the equipment open for a long time, so it screws up my work area, since I still have a open 3310B and a 33a sorensen open right now and some new stuff coming in mail
Trying to maintain FIFO because I had some of these broken since like 2016 and its just too much so I am trying to force it. Also need to fix a negative voltage problem on my 4 adjustment digit voltage¤t source and add a IEC connector to it.. I should not have bought the low noise oscillator but I could not resist and that probobly needs repair and I need to make a graphite wear plate for my pace solder extractor.
I do feel like if I got the scope in order first maybe it would make the 3310b easier to trouble shoot, the 1052E was pissing me off... and the freaking horizontal adjustment encoder suddenly became dicky too, and my scopemeter needs serious plastics welding repairs to feel safe on the bench lol, then the front panel on my wavetek 395 broke too and its hung on by duct tape (2 plastic repair jobs), and my shaft repair on the sorensen power supply is not working (something is wrong with the DP8810 acrylic adhesive!, if it would just cure I can give it a wire wrap job and put it back on the shelf), then the lqd-422 needs a new voltage reference
my house feels a little bit like the b52 in the end of doctor strangelove lol, everything is jammed up sparking and blinking
