Author Topic: Focusrite Forte audio device repair - step-down DC-DC converter problem  (Read 1569 times)
Offline lasworrenTopic starter
Hello,
I'm trying to repair a Focusrite Forte, a PC/MAC usb audio device.
It can work only via usb, but for phantom power it needs external power supply, 5V 1A.
At the moment is dead, no power-up at all.
I've checked the pcb and found a burnt smd autoswitching power mux ic (Tps2113Apwr, U21 on PCB, already changed).
There are also two shorted sot23-5 step-down DC-DC converter, marked as "GALRXA" (U6-U7 on PCB).
Found them here: http://chip.tomsk.ru/chip/chipdoc.nsf/vc1!readform&view=smd&cat=G&start=1501&count=500
described as NCP1521BSNT1G - NCP1521B - TSOP-5 - 1.5MHz, 600mA Step-Down DC-DC Converter. Probably adjustable version.
I suppose the damage was caused by a wrong external power supply, probably 12v instead of 5V.
Anyway, I've found exactly the same step-down converters on aliexpress, already purchased (and arrived after 5 months!). Same package, but marked as "QUW" instead of "GALxxx". I searched online for information on these ic but can't find anything for sot23-5 package.
What can I do? Do I trust the Aliexpress seller? Can I use some other buck converter, always adjustable but working on a different frequency?
thanks
f
Offline fzabkar
Re: Focusrite Forte audio device repair - step-down DC-DC converter problem
« Reply #1 on: February 03, 2020, 03:09:15 am »
TLV70218DBVR, Texas Instruments, 1.8V, 300mA, LDO regulator, SOT23-5, marking QUW:
http://www.ti.com/lit/gpn/tlv702
Did you try here?
https://it.farnell.com/on-semiconductor/ncp1521bsnt1g/converter-buck-adj-o-p-0-6a-smd/dp/1432258
« Last Edit: February 03, 2020, 03:13:24 am by fzabkar »
The following users thanked this post: lasworren
« Reply #2 on: February 04, 2020, 12:59:41 pm »
Thank you! At the end, I'll try to buy original NCP1521BSNT1G from another shop.
Did you try here?
Yes, it's also available on mouser.it, digikey.it, etc., but too expensive shipping costs (about 15-20 eur) for €2 worth of ICs.  |O
