Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Bridge rectifier replacement options
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Bridge rectifier replacement options (Read 731 times)
kasumyku
Regular Contributor
on:
February 01, 2020, 11:42:25 pm »
Hi everyone,
I’m trying to repair a 15V 2A variable DC power supply.
The bridge rectifier overheated and blown so I was wondering if I can replace it with a different rectifier because it looks like this power supply was built with whatever parts were available
The one used is KBP210 (see pic), I’ve also attached data sheet.
Thanks!
Logged
cowasaki
Frequent Contributor
Country:
Re: Bridge rectifier replacement options
Reply #1 on:
February 02, 2020, 12:38:18 am »
As long as the power handling is the same or higher you just need something that will fit physically and have the same pinout . That is a pretty standard device.
Logged
gbaddeley
Regular Contributor
Country:
Reply #2 on:
February 04, 2020, 09:50:09 am »
Agree, I would go for at least a 100 PIV rated at least 5 - 10 A to give a good overload margin. Bridges are cheap, so don’t scrimp.
Logged
Glenn
exe
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
