It seems the ribbon cable for your LCD is too short.
I suspect the LCD is the wrong one for your scope.
Your are correct, it should be longer than the one you have.
Return it to your supplier and get the correct LCD.
You have removed the front panel labels so I expect your scope is a rebrand of Siglent SDS1102CML.
What is the brand of your scope?
