Ouch
Yea really. Thanks for the schematic, wasn't able to find it earlier. Bad news follows ...
Have you tried to fix the resistor? Put the lead back in place and touch the connection with your soldering iron. If the central point measures 50 ohms to ground, you're done.
Ed
I was going to attempt to but when I touched the end of it with my soldering iron the end of the resistor just fell off. In any case there was hardly any sliver plating left to solder to anyway. This is old parts I'm dealing with.
First thanks to everyone for their inputs I was studying the options and before that I was going to scab in a cheap 50 ohm resistor in place of the broken red one, just to see if the sensor would behave at a low frequency - i.e. without the erratic way it was acting. But the party is over for now.
When I heated up the place where the two red resistors and two diodes meet (center pin of the N connector), the solder indeed melted. However, even being careful all the parts moved a bit, and one of the tan colored 160 ohm resistors broke, even though it was at the other end of a diode. Wow really? It's that delicate?
So that puts an end to things for now. I will put all the parts in a bag, and perhaps get back to it at a future date. Fortunately I have another Boonton sensor (41-4A) that works, even though it doesn't have the frequency rating of this one, it's OK for my needs.
Any closing advice accepted of course. If you have suggestion as how to proceed at this point, please advise
