Author Topic: Anyone understand on fridge fuse working mechanism ?  (Read 565 times)
Offline abdulbadiiTopic starter
« on: January 11, 2023, 02:21:16 am »
Anyone familiar or understand on fridge fuse working mechanism ?
I'm almost blind about it
« Last Edit: January 11, 2023, 02:24:12 am by abdulbadii »
Offline DavidKo
  • Country: cz
Re: Anyone understand on fridge fuse working mechanism ?
« Reply #1 on: January 11, 2023, 05:17:30 am »
Do you mean the bimetal temperature fuse on the compressor? Fridge stops working and starts again in intervals, but it does not cool. In my case this was caused with defect "relay" for startup winding which had caused over heating.
The following users thanked this post: abdulbadii
Offline CatalinaWOW
« Reply #2 on: January 11, 2023, 05:30:42 am »
If you are asking how the fuse (actually a switch) works, it is a simple bimetal disk formed into an appropriate dome shape.  Contact is from the top of the dome and the rim.  When the higher expansion coefficient metal on the outside of the dome expands enough it forces the dome to invert breaking contact.
Depending on the metals and exact shape of the disk the inversion can be permanent, or reverse when the temperature drops again.
In most cases the switching temperature is set at the manufacturer, but there are rare cases where an adjustment screw allows some tweeking.
Googling "bimetal thermal switches" and "snap disks" should get you enough reading material to keep you going for weeks.
« Last Edit: January 11, 2023, 05:32:20 am by CatalinaWOW »
« Reply #3 on: January 11, 2023, 06:23:54 am »
What'd be the main purpose of airtight pouch there
Offline Nusa
« Reply #4 on: January 11, 2023, 06:30:46 am »
Keeps moisture out, which prevents corrosion.
