I have two of these amplifiers. The first failed (stopped enabling in response to the trigger input) just a couple of days before a championship football game several years ago - so I ordered a second and put the first on the side for repair.
Recently, I've gone through the first unit. When I opened it, I immediately saw a couple of bulged caps, so I made the decision to replace all of the elec. caps on all 4 internal boards - however I ended up not replacing the low-leakage caps as I tested several of them (they were all good for value/esr/leakage at rated WV). The first unit does work now (there were many bad caps that had drifted in value or were really leaky - I measured them all and recorded results for each). I've now run 150W sustained into a 4 Ohm dummy load for 10 minutes or so and looked around for other problems. As a final check, I looked for any DC offset on the speaker outputs, and I'm getting 0.25V. I also checked the second unit that is currently in service and still has all of its factory parts, and the second unit is showing 0.17V of offset (maybe this is why folks complain of speaker pop with this amp when it enables).
I'm not aware of any public schematics or service manuals on this model, and I've also searched for the same on the Snell SPA750 (appears to be the same SW amp). I've reversed some of the circuitry in this unit, but I'm hoping someone has figured out a thing or two on the amplifier board so I don't have to pull it back out. There are two pots on the amplifier board, and I also see a quad jfet op-amp package (so I'm asking myself is this DC servo'd or not). I'm also reading in other forums that this model has a tracking downconverter on it, which I'm thinking is a fancy linear regulator that varies the rail voltages based on audio level. If so, it seems that this would muddy the waters on the output DC offset at any operating point other than having the output enabled with no audio. This may be OK as long as the DC offset doesn't mover around too much I guess.
Hopefully someone has gone down this path before and has figured out how to adjust the DC offset on this unit. I contacted Dayton, and so far I haven't received any reply.
Thanks for any information that you can share.
