Author Topic: Need Help Locating Replacement USB C Connector For Asus C433  (Read 1398 times)
Offline iamdarkyoshiTopic starter
« on: March 14, 2020, 12:32:21 am »
So a customer's USB C port broke on their Asus C433T chromebook. A new board is almost 200$, which is a stupid amount of money for a chromebook motherboard. All that appears to be wrong is that the USB C port that it charges from is broken, and unfortunately it doesn't appear to be a common connector.
Here's some photos: https://imgur.com/a/j42XdNF
As you can see, it hangs below the PCB (instead of being centered in the PCB), as well as being through hole, and I and I can't seem to find anything that matches it.
The closest I could find is this: https://www.aliexpress.com/item/33009758122.html which doesn't appear to sink the connector below the PCB like the original jack is, and I can't see how the pins are arranged. Thanks for that, aliexpress seller. The original jack appears to have two rows of pins, but I don't know if there's any surface mount crap underneath it.
I'm really not sure what to look for on mouser, digikey, arrow, etc since there's so many options.
What would you guys suggest? Do you know what part this could be or where to source it?
Offline PeteH
Re: Need Help Locating Replacement USB C Connector For Asus C433
« Reply #1 on: March 14, 2020, 02:20:07 am »
Hard one to locate. Not sure where it'll be available in low quantity
https://m.globalsources.com/gsol/I/USB-3.1/p/sm/1165984404.htm
« Last Edit: March 14, 2020, 02:31:32 am by PeteH »
Offline JKKDev
  • Country: si
« Last Edit: March 14, 2020, 06:06:40 am by JKKDev »
Offline amyk
« Reply #3 on: March 15, 2020, 08:34:34 pm »
Imgur says I need to sign on due to potential adult/erotic content? What TF?
Because it shows a... female connector. :-DD
« Reply #4 on: March 16, 2020, 04:31:51 pm »
Stupid AI bullshit thinking my finger is tits or something
Try these:
https://i.imgur.com/8G0zyG8_d.jpg?maxwidth=69420
https://i.imgur.com/3ntR39J_d.jpg?maxwidth=69420
https://i.imgur.com/Xf8ZDeE_d.jpg?maxwidth=69420
« Reply #5 on: March 16, 2020, 05:02:59 pm »
So I removed the USB C connector and sadly it doesn't look like any of the options posted so far.
Apologies for potatocam, I can't find my magnifying lens, so I have to use digital zoom AKA crop and upscale
Some are really close, but nothing matching.
But I've now spotted that the machine has another USB C port on the daughterboard, and it won't charge off of it either.
I'm wondering if the original port breaking has damaged the mainboard now... With the potential to send 20v across the data pins, I wouldn't doubt it
