Author Topic: AOC Monitor - Thin Blue Vertical Line  (Read 178 times)
Online 2XTopic starter
  • Country: gr
« on: August 03, 2024, 07:29:37 pm »
Hello,
I have the below AOC (E2275SWJ) monitor and always shows me a thin blue vertical line.
I moved back and forth the connectors and the COF tabs but the vertical line didn't disappeared with any movement at all.
Do you know If there is any solution?
Offline wasedadoc
Re: AOC Monitor - Thin Blue Vertical Line
« Reply #1 on: August 03, 2024, 07:43:36 pm »
There are not enough connections to have one per column so almost certainly this is a fault within the panel and unfixable.
The following users thanked this post: wraper, 2X
