yep, they will have been knocked off frequency.
A tune should fix it, use a plastic screwdriver or tuning stick.
If it doesn't have any tune-able components in the RF section then look for air core inductors, maybe the impact has bent the coil slightly.
Be very careful and adjust in really fine amounts while listening to it, if you throw it far out of tune you may not be able to find it again.
