Hi, it has a strange fault in that it had the power led just blinking, as stuck in standby. Yes, as you say, it is just normally caps in the supply, as there were four that were bulged up. After replacing all four, now the supply is dead, no led, nothing. Double checked my work, cap values, polarity, even removed the newies and checked them on my cap meter, all good. Thought I may have misplaced a supply plug to the wrong socket or something, as there are a couple of extra sockets more than there are plugs to match, hence my request for a schematic. It has been a while since I stripped it down, so just need to make sure of a couple of things with it.
