Author Topic: AWA DSA-510 Amp  (Read 5859 times)
Offline tazelikechicknTopic starter
AWA DSA-510 Amp
« on: September 04, 2014, 07:59:46 am »
Hey Guys,
I am trying to repair a AWA DSA-510 Amp. I have a standby light on, but will not fire up when I press the switch. The switch etc is ok, but I would like to check out a schematic to see how it works.
Does anyone have access to a Schematic? I have tried all the sites that I know, but no luck.
Thanks for your help.
Online David_AVD
Re: AWA DSA-510 Amp
« Reply #1 on: September 04, 2014, 09:03:11 am »
Does it use a switchmode or conventional transformer power supply?
Re: AWA DSA-510 Amp
« Reply #2 on: September 04, 2014, 09:13:12 am »
Hey Dave,
It is just a standard transformer. It has power coming out (13 V & 6 V) and fuses are OK. No AC power to the bridge rectifier. The relay is not clicking on.
Online David_AVD
Re: AWA DSA-510 Amp
« Reply #3 on: September 04, 2014, 09:16:39 am »
Check for open-circuit relay coil (it happens!) first.
Then move onto the relay drive transistor circuit.  Some amplifiers have a small value electrolytic capacitor that is charged via a separate diode off the power transformer.  If that cap dies, the relay won't kick in.
Other than that, check for cracked solder joints and any sign of overheated resistors (check their value).  That should get you started.
EDIT: Oh, so no AC into the bridge?  I missed that at first read.  Does it have another smaller power transformer?
Re: AWA DSA-510 Amp
« Reply #4 on: September 04, 2014, 11:43:30 am »
No smaller transformer that I can see. I haven't really traced or done a lot of checks at the relay. I see a diode, a few caps and transistor nearby and will check that tomorrow.
Also haven't checked the relay coil or switch operation, but can't hear it click when the button is pressed. I gather it is not being switched. Another job for tomorrow.....
IDIOT ALERT!! I just realised that I was testing the bridge rectifier incorrectly. Damn you AC/DC! Once I checked the right terminals I got 29.7 Volts AC & 35.5 Volts DC - all good. I think I will have to check the relay next. I checked for continuity on the coil, but might have the wrong side. I will desolder it and check it off the board and it should power up with a 9 Volt battery I think?
I have included a photo that should make it easier to understand
BTW thanks for the help - it is greatly appreciated  8)
Online David_AVD
Re: AWA DSA-510 Amp
« Reply #5 on: September 04, 2014, 09:41:55 pm »
When you say it doesn't turn on, maybe you mean that the relay never clicks in and you get no audio from the speaker outputs?
If so, one of the amplifier outputs may have gone DC and the relay circuit is doing its job.
There will be two traces (call them A & B) going from the output stages (heatsink area) to the relay and another two going from the relay (call them C & D) to the speaker terminals.
The relay will be wired with one (normally open) contact between points A & C and another contact between points B & D.
What you need to do is measure the voltage on each of the two traces going to the relay (A & B) with respect to ground.  They should be close to 0V DC.  If not there is an issue with one of the output stages.
Re: AWA DSA-510 Amp
« Reply #6 on: September 04, 2014, 10:04:23 pm »
Great advice Dave,
I will check that when I get some time
Re: AWA DSA-510 Amp
« Reply #7 on: September 05, 2014, 07:42:47 am »
Hey Dave,
I ended up removing the relay, powering it up and checking for continuity either side - all good. When installed, I can physically feel the relay click in and I have consistent power either side of the contacts. Yet it still stays in the standby mode, with the light staying on even when the button is pressed.
Online David_AVD
Re: AWA DSA-510 Amp
« Reply #8 on: September 05, 2014, 09:02:22 am »
I'll see if I can check out a manual for you.
Re: AWA DSA-510 Amp
« Reply #9 on: September 05, 2014, 09:05:02 am »
Much appreciated - thanks
Offline Rasz
    • My random blog.
Re: AWA DSA-510 Amp
« Reply #10 on: September 05, 2014, 09:12:19 am »
check power transistor/whatever is stabilizing voltage after the relay
Re: AWA DSA-510 Amp
« Reply #11 on: September 06, 2014, 09:54:14 pm »
Thanks Rasz,
I have checked the regulators & both positives and negatives are working correctly.
Offline Rasz
    • My random blog.
Re: AWA DSA-510 Amp
« Reply #12 on: September 07, 2014, 06:00:52 am »
ok, so you have +-15v healthy
lets go further, find +5V rail and check if its working
follow the voltage upriver
Re: AWA DSA-510 Amp
« Reply #13 on: September 07, 2014, 07:40:41 am »
Hey Rasz,
Thanks for your reply.
The regs are -+6 & -+12. One thing I did note is that the main wiring loom going from the board to the switching board has 5V, G, M, P, 15V on it and I am only getting 12V at the 15V pin (5V OK - don't know what the others are).
At this point I'm not sure if there is meant to be 15V there as the regs are only meant to be 12V. Or am I barking up the wrong tree?
I have searched high and low for a schematic, but nuh - not gonna happen!
Any help is appreciated.
Online David_AVD
Re: AWA DSA-510 Amp
« Reply #14 on: September 07, 2014, 07:41:36 am »
I have asked for the manual but may take a few days.
Re: AWA DSA-510 Amp
« Reply #15 on: September 07, 2014, 08:02:24 am »
Thanks for your help guys.
In the meantime, I will try and follow the voltage trail.......
Re: AWA DSA-510 Amp
« Reply #16 on: September 16, 2014, 08:06:15 am »
Hey David_AVD,
Have you had a chance to find a manual for the AWA Amp?
I have been doing some voltage checks, but am a little lost without a schematic.
Thanks
Online David_AVD
Re: AWA DSA-510 Amp
« Reply #17 on: September 16, 2014, 11:17:12 am »
I chased up my contact earlier today but no dice.  Sorry.
Re: AWA DSA-510 Amp
« Reply #18 on: September 16, 2014, 10:14:10 pm »
No worries, thanks for your help anyway. Looks like I'll have to go 'old school' and use my brain!! Time is the worst enemy. I seem to forget what I have checked and what I haven't. I have taken photos and marked off what I have checked and this usually works, but just really busy at the moment. Why do we have to work? Why can't we just spent our time doing our hobbies?
I guess that's why they call it a hobby!  :blah:
Thanks again for your help. :-+
