Author Topic: Automotive SMD resistors  (Read 774 times)
Offline AudiorepairTopic starter
« on: May 11, 2022, 06:08:43 pm »
I don't normally repair car stuff, but this was foisted on me today by a friend who didn't want to take no for an answer, as it would cost him dear otherwise.
It's a BMW media control unit, which sits in the boot of the car, apparently.
It had some water damage, including a 1 ohm resistor which needs replacing.
I haven't seen SMD resistors like these before, and scrolling through those available at Farnell I didn't see anything that looked similar, so I don't know why they are packaged like this.
I suspect from the circuitry they are not massively high power, maybe this is some kind of environmental car thing instead.
Photo attached.
« Last Edit: May 11, 2022, 06:15:40 pm by Audiorepair »
Offline TheMG
Re: Automotive SMD resistors
« Reply #1 on: May 11, 2022, 06:20:00 pm »
I believe those are inductors, not resistors.
Likely 1uH (1R0), 10% tolerance (K).
Why they use "R" in the numbering for an inductor, I don't know, but that's something they do.
From the triangle and the letter T, looks like TDK / EPCOS part.
https://product.tdk.com/en/search/inductor/inductor/smd/list#ref=characteristic&2l%5Bunit%5D=1.00E-06&2l%5Bt%5D=1&2ltol%5B%5D=%C2%B110%25&psts%5B%5D=0&_l=20&_p=1&_c=part_no-part_no&_d=0
« Last Edit: May 11, 2022, 06:24:59 pm by TheMG »
« Reply #2 on: May 11, 2022, 06:24:59 pm »
Doh!
I think you are correct.
Exit stage left hoping nobody notices.
Offline inse
« Reply #3 on: May 12, 2022, 04:46:23 am »
Is one of them open, or how did you diagnose it to have failed?
It looks like some kind of supply line filtering, you could bypass the coil for test purpose.
« Reply #4 on: May 12, 2022, 06:07:30 am »
The PCB was corroded, the inductor was detached from one pad, and when I removed it the corroded solder terminal fell off.
I can't test this module, I don't have a BMW to plug it into.
I am repairing it with the understanding I can only repair visibly obvious faults, and can't test it.
This why I don't repair car stuff.
« Reply #5 on: May 12, 2022, 01:02:20 pm »
Thanks,
I found this at Farnell, looks like it will do the job.
https://uk.farnell.com/tdk/nlcv32t-1r0m-efr/inductor-1uh-20-1-7a-100mhz-3225/dp/2747759
