Author Topic: Atten ADS1022C+ not work after firmware upgrade  (Read 5836 times)
Offline ManManTopic starter
  • Country: ru
« on: June 09, 2017, 02:43:01 pm »
Hi All
Please Help !
my Atten ADS1022C+ not work after firmware upgrade ((
I have only flash dump from ADS1102CAL (7" display)
after flash this dump, i upgrade original Atten ADS1000 series firmware from USB, and get an almost working DSO
due to non-compliance hardware ((
I need Atten ADS1022C+..ADS1042..ADS1062 or Siglent SDS1022C  Flash dump.
and Siglent SDS1022C latest Firmware
burningant@mail.ru
The owner of this oscilloscope can not only help me, but also protect yourself by making a dump of your firmware.. All you need to download the firmware DUMP via JTAG is here https://cloud.mail.ru/public/D9hP/vaBkzVoyT
« Last Edit: August 27, 2017, 08:47:51 am by ManMan »
The following users thanked this post: adrianoafg
Offline adrianoafg
  • Country: br
Re: Atten ADS1022C+ not work after firmware upgrade
« Reply #1 on: August 06, 2017, 02:10:41 am »
good evening
I'm having the same problem, I have an atten ads 1102ca and updated with the 1102cal file that is 7 ".
I need the firmware of ads 1102ca or sds1102cm.
Can someone help me?
Thank you.
  • Country: ru
« Reply #2 on: August 07, 2017, 01:00:15 pm »
good evening
Thank you.
ADS1102_Software V2.0
https://drive.google.com/open?id=0B_zX2dDtHzm3R0ozV2poSVUwaU0
ADS1000CA Series_Software V3.0
https://drive.google.com/open?id=0B_zX2dDtHzm3OHVYejNROWtWbnc
« Last Edit: August 07, 2017, 01:03:17 pm by ManMan »
Offline kimer23
« Reply #3 on: October 27, 2017, 09:03:28 pm »
good evening
Thank you.
I have ADS1022C+ . I build WIGGLER JTAG. I run TopJTAGFlash and  update *.ads file format. After ca. 3h update completed and scope displayed dark screen. I need correctly dump for my scope. Thx
  • Country: ru
« Reply #4 on: December 07, 2019, 10:30:31 pm »
Hi, All
after much torment, I managed to assemble a work dump from the parts..
All Working fine!  :)
Offline koshi
  • Country: ru
« Reply #5 on: June 01, 2020, 01:15:49 pm »
Thanks a lot!
So as all of you trying to fix bugs on my siglent sds1102cm 5" by flashing sds1102cnl firmware
I flash mydso_ok.zip  directly in S29GL032n90TFI04 by programmer, because it's too quickly for me. Now it's works perfectly well, but recognising as ADS1102C+. I think, this dump will be work with all ADS1042C+    ADS1022C+ and SDS1152CM    SDS1102CM    SDS1062CM models. Lecroy PC application easy scope  Version 3.01.03.01.09  https://teledynelecroy.com/support/softwaredownload/easyscope.aspx works perfectly good for me
The following users thanked this post: sever2k6
Offline mizohalen
  • Country: at
« Reply #6 on: December 11, 2022, 06:03:49 pm »
Hello I have done the same mistake of flashing the 7 inch firmware for my ATTEN ADS 1062C ...now it is unusuable.
an you give me please acces to these firmware files? Thanks !
Offline mizohalen
  • Country: at
« Reply #7 on: December 11, 2022, 06:04:28 pm »
good evening
Thank you.
