Author Topic: Attempting to repair an insanely cheap LCD display (why the waste? )  (Read 2856 times)
Offline Razor512Topic starter
An 8 inch LCD panel failed on me (Display came with a $200 4 security camera + 500GB networked DVR)
I noticed, 2 different ribbon cables (same pin count), Only issue is that the transparent ribbon cable is long enough to reach the connector on the PCB. The LCD is obviously designed to be as cheap as possible, so why add that extra bit of stuff?
The extra PCB has no special components on it.
I attached 2 images of the seemingly unnecessary part.
Overall, why the waste?
(click for full size)
LCD-1 by Razor512, on Flickr
LCD-2 by Razor512, on Flickr
Offline amyk
Re: Attempting to repair an insanely cheap LCD display (why the waste? )
« Reply #1 on: June 05, 2013, 09:12:05 am »
There might be several other models with a similar BOM, and the extender PCB + connectors might've been cheaper than ordering another custom length of flex.
Or maybe it's a debugging facility of some sort...
Offline bilko
« Reply #2 on: June 05, 2013, 09:18:00 am »
It looks like it might be an extender cable to allow board testing. Should have been removed before assembly
Offline ptricks
« Reply #3 on: June 05, 2013, 10:53:19 am »
The type of connector that is on the LCD is very fragile and while it might reach , someone assembling it without that board in between could easy damage it.
Offline Rufus
« Reply #4 on: June 05, 2013, 11:46:17 am »
Looks like it might be too short for easy assembly without the extension. Otherwise FPC cables and connectors have contact up and contact down styles which the board and cable might be changing.
« Reply #5 on: June 06, 2013, 07:59:33 pm »
Seems that I am unable to fix it, all of the passives seem to work so it most be that crappy SOC that reaches around 70C after a minute or 2 or being on and displaying a black screen with no OSD.
Guess I will have to look for an old portable TV or something else thats cheap to use as a display when not monitoring from my computer or tablet or smartphone.
Offline amyk
« Reply #6 on: June 07, 2013, 12:41:04 pm »
Have you checked the caps? Might be too much ripple?
FYI here's datasheet and related documents on the IC...
http://cache.ourdev.cn/bbs_upload782111/files_49/ourdev_706832C2JGB9.rar
