N.B. Last night I did different EEPROM dumps with Floppy on 2G healthy and 1G failed TDS540's, see attached where the 2G always generates the same EEPROM binary file. However on the 1G, there are different failed dump which can be attributed either to failed Floppy driver installed on 1G or something else on the acquisition board. Since the floppy disk is the same wether I read 2G scope or 1G scope, I'd tend to conclude the disk is OK.
On a side note, the DOS application ACQUEDUMP in charge of EEPROM dump seems to use internal GPIB link, see
nulldev = open("/null",3,0666)
taskSpawn "Redirect",1,0,0x4000,ioGlobalStdSet,1,nulldev
taskDelay (600)
GpibInput("WAITICON OPEN")
GpibInput("mess:box 80,80,450,200")
GpibInput("mess:show \"\n\n\n\n ACQ EEPROM dump to floppy started, please wait.\"")
acqEEPROMSize=0x200
tempBuf=malloc(acqEEPROMSize)
_gtlX24c02Bcopy(0x10A00000,tempBuf,acqEEPROMSize)
ls "fd0:/"
fd=open("fd0:/acqeeprm.bin",0x0202,0777)
bytesWritten=write(fd,tempBuf,acqEEPROMSize)
close(fd)
confmsg=malloc(500)
sprintf(confmsg, "mess:show \"\n\n\n\n Dump completed, power off instrument.\n\n")
sprintf(confmsg+strlen(confmsg), " Bytes requested: %d \n Bytes written to disk: %d \n\"", acqEEPROMSize, bytesWritten)
GpibInput(confmsg)
GpibInput("WAITICON CLOSE")
GpibInput("bel")
This code calls _gtlX24c02Bcopy subroutine which can be precisely found inside the firmware when doing a TEXT search
However the getcaldata source code does use another method from the external GPIB interface, see
* CAL EEPROM backup - for TDS520B,TDS540B,TDS724A,TDS744A,TDS754A,TDS782A,TDS784A
* compiled with MinGW gcc on Windows Vista / Win7
* tested with Agilent I/O 16.x and S82357 from [url]http://bmjd.biz/index.php[/url]
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <errno.h>
#if defined(WIN32) || defined(_WIN32) || defined(__WIN32__) || defined(__NT__)
#include <conio.h>
#include <windows.h>
/* for NI adapters uncomment following line */
/* for Agilent adapters uncomment following line */
#include "ni488.h"
#elif defined(__linux__)
/* linux with linux-gpib */
#include <gpib/ib.h>
#elif defined(__APPLE__)
/* MacOS with NI GPIB drivers */
#include <ni4882.h>
#else
#error "Unknown compiler environment!"
#endif
#if !defined (PROG_NAME)
#define PROG_NAME __FILE__
#endif
#if !defined (GIT_VERSION)
#define GIT_VERSION "unknown"
#endif
#if !defined (BUILD_TIME)
#define BUILD_TIME __DATE__ " " __TIME__
#endif
#define ARRAYSIZE 100 // Size of read buffer
int Dev; // Device handle
char ReadBuffer[ARRAYSIZE + 1]; // Read data buffer
char ErrorMnemonic[21][5] = {"EDVR", "ECIC", "ENOL", "EADR", "EARG",
"ESAC", "EABO", "ENEB", "EDMA", "",
"EOIP", "ECAP", "EFSO", "", "EBUS",
"ESTB", "ESRQ", "", "", "", "ETAB"};
void GPIBCleanup(int Dev, char* ErrorMsg);
static int debug;
static char* ident = PROG_NAME " Version: " GIT_VERSION " Build time: " BUILD_TIME;
static void print_version(void)
fprintf(stderr, "# %s\n", ident);
int main(void) {
* INITIALIZATION SECTION
* Assign a unique identifier to the device and store in the variable
* Dev. If the ERR bit is set in ibsta, call GPIBCleanup with an
* error message. Otherwise, the device handle, Dev, is returned and
* is used in all subsequent calls to the device.
#define BDINDEX 0 // Board Index
#define PRIMARY_ADDR_OF_DMM 1 // Primary address of device
#define NO_SECONDARY_ADDR 0 // Secondary address of device
#define TIMEOUT T10s // Timeout value = 10 seconds
#define EOTMODE 1 // Enable the END message
#define EOSMODE 0 // Disable the EOS mode
FILE *outfile;
int f;
#if 0
unsigned long addr;
// addr = 0x00040000L; /* CAL data base address on TDS5xxB,6xxA,7xxA*/
addr = 262144; /* CAL data base address on TDS5xxB,6xxA,7xxA*/
#endif
print_version();
Dev = ibdev (BDINDEX, PRIMARY_ADDR_OF_DMM, NO_SECONDARY_ADDR,
TIMEOUT, EOTMODE, EOSMODE);
if (ibsta & ERR)
GPIBCleanup(Dev, "Unable to open device");
return 1;
* Clear the internal or device functions of the device. If the error
* bit ERR is set in ibsta, call GPIBCleanup with an error message.
ibclr (Dev);
if (ibsta & ERR)
GPIBCleanup(Dev, "Unable to clear device");
return 1;
* MAIN BODY SECTION
* In this application, the Main Body communicates with the instrument
* by writing a command to it and reading its response.
ibwrt (Dev, "*IDN?", 5L);
if (ibsta & ERR)
GPIBCleanup(Dev, "Unable to write to device");
return 1;
ibrd (Dev, ReadBuffer, ARRAYSIZE);
if (ibsta & ERR)
GPIBCleanup(Dev, "Unable to read data from device");
return 1;
ReadBuffer[ibcntl] = '\0';
printf("DSO IDN: %s\n", ReadBuffer);
outfile = fopen("U1052.bin","wb");
printf("dumping U1052.bin\n");
printf("\nPlease wait ...\n");
/* the first 8 bytes of the U1052 EEPROM are not mapped and empty (0x00h)
so we write as well 8 time 0x00h to dump file */
for(f = 0; f < 8; f++)
fputc(0x00, outfile);
/* send first TEKTRONIX Password fr TDS5xxB/7xxA models to allow memory dump */
ibwrt (Dev, "PASSWORD PITBULL", 17L);
if (ibsta & ERR)
return 1;
unsigned char calbuf[255];
int caldata;
for(f = 0; f < 124; f++)
char cmdbuf[64] = "WORDCONSTANT:ATOFFSET? 262144,";
char cmdnr[16];
sprintf(cmdnr,"%d",f);
strcat(cmdbuf, cmdnr);
if (debug > 1) printf("DSO IDN: %s\n", cmdbuf);
ibwrt (Dev, cmdbuf, sizeof(cmdbuf));
if (ibsta & ERR)
return 1;
ibrd(Dev, calbuf, 6);
if (ibsta & ERR)
return 1;
caldata = atoi((char *) calbuf);
if (debug > 1) printf("CAL DATA: %X\n", caldata);
unsigned char* abuffer = (unsigned char *)&caldata;
fputc(abuffer[1], outfile);
fputc(abuffer[0], outfile);
fclose(outfile);
outfile = fopen("U1055.bin","wb");
printf("dumping U1055.bin\n");
for(f = 0; f < 128; f++)
char cmdnr[16];
sprintf(cmdnr,"%d",f+124);
if (ibsta & ERR)
return 1;
if (ibsta & ERR)
return 1;
fclose(outfile);
printf("\nCalibration data has been successful dumped\n");
* CLEANUP SECTION
/* Take the device offline. */
ibonl (Dev, 0);
return 0;
* After each GPIB call, the application checks whether the call
* succeeded. If an NI-488.2 call fails, the GPIB driver sets the
* corresponding bit in the global status variable. If the call
* failed, this procedure prints an error message, takes the
* device offline and exits.
void GPIBCleanup(int ud, char* ErrorMsg)
printf("Error : %s\nibsta = 0x%x iberr = %d (%s)\n",
ErrorMsg, ibsta, iberr, ErrorMnemonic[iberr]);
if (ud != -1)
printf("Cleanup: Taking device offline\n");
ibonl (ud, 0);
So for sure there are two software and probably hardware method to READ the EEPROM where for some reason, one fails possibly explaining the FAIL of the oscilloscope
