Found yesterday a discarded 9Ah/12V UPS battery. It was written on it "Maintenance-free Sealed Lead-acid Battery", which remembered me about this thread and Circlotron's reverse charging recovery method:
https://www.eevblog.com/forum/repair/attempt-rejuvenating-old-gel-cell-lead-acid-batteries-with-a-bench-supply/msg1985024/#msg1985024 , so I took it home out of curiosity to test the reversed charging recovery.
The battery measured 3.5V with no load, and took no charging current when trying to charge it with 14.4V and the correct polarity. Since it was a lead-acid battery and not a gel one, I first assumed it was dried out. Cracked open the top cover, removed the rubber plugs and fill each element with de-ionized water until the water was was about 3 mm above the plates.
After filling it with water I was expecting to take at least a few mA in normal charging mode, but nope. Still nothing, so I connected the battery with reversed polarity (- of the battery to the + of the charger), with the power source set at 14.4V/180mA max. The current indicated by the power supply was about 30mA at first, and in a few minutes reached the 180mA set limit
To my surprise, after a few minutes of reversed charging, the voltage started to jump/fluctuate (about a few times a second, or so, between jumps), also it was some very, very slow gassing (I left the rubber plugs opened), so I start
logging the voltage at each minute.
Strangely, the time between voltage jumps was random, but the voltage was about 1.2V or so.
Today I give it another try, this time using good wires instead of the very cheap Chinese banana/alligators wires from yesterday. Now there are no more voltage jumps, and I'm curios if this is because the plates had time to soak over night, or because of the good wires.
TL;DR
Anybody remember seeing voltage variations jumping approx. 1.2V up and down during reverse charging?
