Hi Andy,
I did not forget about this but I had other priorities that got first.
The caps C25, C26, C75 and C76 were soldered out of the board and checked using my MTester (Peak ESR meter like device).
The C75/C76 came up with an ESR of resp. 15 Ohms and 10 Ohms and a voltage loss of resp. 2,1 % and 1,9 %.
The caps C25/C26 came up with an ESR reading of resp. 5,4 Ohms and 6,1 Ohm, with a voltage loss of 1,1 % and 1,9%.
The C25 and C26 were changed out for new ones with the same specs but the other two were not changed out as I do not have them in stock.
Don't know if it is of any use to you. But I wonder if the ESR on the C75/76 is normal that high?
The transistors are swapped. I numbered them on the rail and on each of the transistors themselves. Then I made a swap as you suggested.
Took the transistors off the board using solder wick and soldering them back with fresh new solder
I regret that I did not first check the result after the recap and before the interchanged trans'.
Also did a visual check for dry soldering but couldn't find any yet. So maybe, when things start to fall back again, maybe a recap is in order.
I hooked the unit up now to some speakers and a CD player and will test it to see what happens.
Greetings,
Dan
