Author Topic: AWA LCD TV CL-40KDF10S SCHEMATIC  (Read 1339 times)
Offline geobeeTopic starter
« on: November 28, 2016, 06:58:32 am »
Hi all, at a dead end trying to locate a schematic for this LCD tv set.   Tried all my usual resources to no avail. Any help would be much appreciated. Regards.
Offline Rasz
    • My random blog.
Re: AWA LCD TV CL-40KDF10S SCHEMATIC
« Reply #1 on: December 01, 2016, 07:34:56 am »
you dont need a schematic, it would be useless to you anyway.
its either something simple like caps/bad inverter, or uneconomical like scaler chip or panel
« Reply #2 on: December 03, 2016, 12:53:12 pm »
Hi, it has a strange fault in that it had the power led just blinking, as stuck in standby. Yes, as you say, it is just normally caps in the supply, as there were four that were bulged up. After replacing all four, now the supply is dead, no led, nothing. Double checked my work, cap values, polarity, even removed the newies and checked them on my cap meter, all good. Thought I may have misplaced a supply plug to the wrong socket or something, as there are a couple of extra sockets more than there are plugs to match, hence my request for a schematic. It has been a while since I stripped it down, so just need to make sure of a couple of things with it.
