Author Topic: Fluke 189 strange readings  (Read 5778 times)
Offline Samogon
Re: Fluke 189 strange readings
« Reply #25 on: September 03, 2019, 08:22:21 pm »
I believe it is ADC chip, meter is on the waiting for repair shelf, will update when i start working on it.
Yes, please, do let us know of anything else you may find when working on it.
Thanks!
So in my case it was ADC asic, and i have found that any slight contamination causes it erratic readings.
« Last Edit: September 03, 2019, 08:25:38 pm by Samogon »
Offline retiredcaps
« Reply #26 on: September 03, 2019, 10:25:13 pm »
Does anyone know if the buzzer will eventually recover, or I'd better look for a replacement?
Has the buzzer improved?  Maybe it's still not dry with IPA trapped inside?  Maybe direct some air to the hole?
If not improved, you could probably get a replacement from digikey/mouser.  I don't know the part number or specs, but you could probably find the right parameters using a scope?
Offline retiredcaps
« Reply #27 on: September 03, 2019, 10:27:03 pm »
It's not clear to me so can you please clarify if you actually replaced the ADC or just washed it with IPA?
Offline Samogon
« Reply #28 on: September 03, 2019, 11:59:40 pm »
I did replace ASIC. And it fixed one of the problems reading 10 Ohms on short.
I just noticed that any contamination of this greatly affects reading. I made several cleaning steps and every step showed improvement. Lastly i ran it in the Crest ultrasonic cleaner with Branson EC 3% solution.
That brought it to specs operation.
Offline giosifTopic starter
« Reply #29 on: September 14, 2019, 09:36:30 am »
No, it hasn't.
I tried applying heat, blowing air, bumping it on the sides, then on the top and bottom, but there was no change.
I tested again even now, and it is the same.
One thing I did notice, though, was that, if I let the buzzer sound continuously for 1 minute or so, it would start to become louder.
But, then, if I let it sit half a minute or so and sound the buzzer again, it would go back to a fainter sound.
In the end, I just bought a cheap 5V buzzer off eBay - probably an unknown brand, but I don't think that matters for this kind of component.
« Reply #30 on: September 14, 2019, 09:38:02 am »
And had you tried these same cleaning steps with the original ASIC?
Or that was definitely broken?
Offline Samogon
« Reply #31 on: September 14, 2019, 04:36:48 pm »
Yes both times ultrasonic cleaning.
I was just curious how it would behave before cleaning, it was awful, erroneously reading buzzer going off all the time.
« Reply #32 on: September 14, 2019, 10:30:10 pm »
Oh, wow.
So, it couldn't have been just contamination for the original ASIC.
I wonder what else it could have happened to it, then: overvoltage?
Offline Samogon
« Reply #33 on: September 15, 2019, 01:18:27 am »
Nope original was bad, replacement did the trick. My point was that this area really sensitive. Which my tests before snd after cleaning proved
