Hi , I was wondering if anyone could help me identify a part, or recommend a suitable value to replace with.
Recently my beard trimmer started to display a fault where it only ran for 30sec before grinding to a halt. I suspected the battery as the unit is old. However after replacing the cell, the device had the same issue.
After poking around of a while I discovered that the PTC right near the positive to the motor was faulty. I would like to replace it, however Im not experienced enough to know what value to use.
The device is a Remingtion MB6550 and it runs a single 18500a Li-ion cel.
I've attached a photo of the faulty component, does anyone have any suggestions for me ?
![](https://i.ibb.co/7yY8kZJ/IMG-20230214-165641-Small.jpg)
