Author Topic: Zener regulation  (Read 3661 times)
Offline ElesquareTopic starter
Zener regulation
« on: April 17, 2015, 09:57:17 pm »
I've got a cheap led light that didn't work. Supply voltage is made by zener regulation and there was a shorted diode (can't be another zener, can it? No markings, however) in parallel with zeners. After removing this, the light is working again.
What's the purpose of that diode?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Zener regulation
« Reply #1 on: April 18, 2015, 06:19:29 am »
It's literally on a resistor and cap, and nothing else??
What markings on it?
Seven Transistor Labs, LLC
« Reply #2 on: April 18, 2015, 07:23:42 am »
Good morning,
after a good night's sleep it looks that I shouldn't have forgotten the second half of the circuit: there's a light sensor, too.
The mysterious diode must be making proper voltage for darlington! So with diode removed the switching point may be affected. But if I can live with it, there's nothing dangerous about that fix. Am I right?
« Last Edit: April 18, 2015, 07:25:36 am by Elesquare »
Offline Seekonk
« Reply #3 on: April 18, 2015, 07:59:44 am »
It may not work for long if current can get high enough.  D form a reference voltage for the constant current amplifier.  Figure what current the LED should be at.  Multiply that by the 75 ohm resistor for the voltage and add 1.2V for the darlington. That will be the rough voltage for the zener.
« Reply #4 on: April 18, 2015, 08:44:54 am »
I have no idea of led (panel) current or even number of leds. Absolute maximum current with 240V mains and 100 ohm resistor after bridge is about 1.2A. Transistors are propably BC817, so max collector current is 500mA. Thus max voltage for D is 36V?
Offline Fank1
« Reply #5 on: April 18, 2015, 11:10:54 am »
It's a classic zener voltage regulator circuit, designed to keep the voltage on the 75 ohm resistor constant and as a result the current thru the led's is regulated.
Offline Seekonk
« Reply #6 on: April 18, 2015, 01:53:45 pm »
Lets throw out some numbers. Suppose that 75 ohm is a 1W.
100ma X 75 ohms = 7.5V
100ma X 7.5V = .75W
7.5V + 1.2V = 8.7V .......8.2V zener
Using ohms law you can solve this for any size resistor.  Your actual current is probably 15-20ma.
« Reply #7 on: April 19, 2015, 07:07:02 pm »
Just installed 5V1 zener and lamp seems not too bright at all in full darkness. Going to give it a chance now!
Thank you for help, all of you!
