Author Topic: Oscilloscope repair  (Read 7370 times)
Offline dexters_labTopic starter
Oscilloscope repair
« on: November 28, 2009, 05:28:08 pm »
i have an old Gould 1421 Analog/Digital (circa mid 80s) scope thats gone faulty on me and wondered if someone could suggest an area of it's internals that would be a good place to start looking. Thankfully i do have a schema.
The problem is on the display, on both channels the trace seems to fold back into a central point on the crt that never moves. Looking past the funny visual i can see a signal being displayed and the storage side all seem to work so i suspect it's something with the crt driver side.
I have a short video of the fault here: http://www.mr2.net/media/gould1421fault2.wmv
Offline qno
Re: Oscilloscope repair
« Reply #1 on: November 29, 2009, 09:55:35 am »
It looks to me like some kind of power supply problem.
It looks like the x and y amp break down resulting in the beam ending up in the middle of the screen.
Because this is both x and y I would start in the power supply. Look for oscillating or constant switching on off.
The problem could be a capacitor that has lost all capacitance or something simple as a bad connector or a broken PCB track
Why spend money I don't have on things I don't need to impress people I don't like?
Offline Neilm
« Reply #2 on: December 02, 2009, 07:29:12 pm »
It is worth just reminding you that any CRT has some high voltages in it. So be careful when probing around and make sure that any caps are discharged.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #3 on: December 09, 2009, 08:03:44 pm »
thanks guys, will check psu and see. It's certainly old enough for bad caps.
« Last Edit: December 09, 2009, 08:51:18 pm by dexters_lab »
Offline qno
« Reply #4 on: December 10, 2009, 12:40:06 pm »
Also check for broken power resistors.
walterdelbono
  • Guest
« Reply #5 on: December 10, 2009, 09:45:36 pm »
awesome video...
good luck...
