Wouldn't a spark oxidize it even more? Also, what sort of voltage/current limits do you mean? I have a 50V, 0.5A supply I use for everything - think that would be reasonable?
You would think it would wreck it even worse, but 'taint the case...
Back in my C-130 days, we had a relay panel, lots of relays, called the 'NIRP' (navigation instrument relay panel), contacts would fail all the time, low voltage contacts.
The NIRP tester was nothing more than a momentary relay coil energizer and would shoot AC across the contacts for awhile until either you gave up or the relay started working.
Seems that generally if you put DC across relay contacts, one side will lose material, and the other side will gain it, and in the process, both sides would be full of garbage and not make contact. Shoot the current in the other direction basically blasts the crud off the contacts and 'fixes' it, at least for awhile.
