Author Topic: Tek SG5030 E350 error  (Read 1185 times)
Offline syauTopic starter
  • Country: hk
« on: June 23, 2020, 11:43:56 pm »
Scored a SG3050 with level head, it will throw a E350 error after output enable for a few seconds. Googled and found not much information in repairing this unit.
Will tear it apart and see if any obvious things happened.
Offline picburner
Re: Tek SG5030 E350 error
« Reply #1 on: June 24, 2020, 10:58:33 am »
You can find something here.
There is also the manual with the schematics.
Offline picburner
« Reply #2 on: June 24, 2020, 11:13:03 am »
and this is the answer of the manual regarding the E350 error:
  • Country: hk
« Reply #3 on: June 24, 2020, 03:24:03 pm »
Open up the unit, smell fishy and all SMD capacitor leaking  :wtf:
1006560-0
1006562-1
Also, this type of PCB is my most dislike one as the pad tend to come off very easy  :--
  • Country: hk
« Reply #4 on: June 24, 2020, 03:25:45 pm »
Not much usable troubleshooting information / flow chart. But lucky schematic provided  :-+
Offline texaspyro
« Reply #5 on: June 25, 2020, 06:30:33 am »
Most levelng head problems that I have seen are due to contact issues with the relays.   The relays consist of a top part (head) that is screwed to the PCB.  It includes the magnets and a leaf spring contact on a pivot.  The contacts touch pads on the PCB.  Remove the relay heads,  inspect and clean (VERY carefully) the leaf springs,  and clean the PCB pads.
Offline wizard69
« Reply #6 on: June 25, 2020, 07:20:25 am »
Best of luck with this unit.   It is obvious that a complete recap is needed.   Hopefully you will have a running unit.   I love this old Tektronix hardware, it is too bad they gave up on it.
  • Country: hk
« Reply #7 on: June 25, 2020, 08:03:03 am »
All SMD cap leaking with corrosion around  :palm: Besides cap, ordered some resistor, capacitor, op amp. Spend whole day cleaning up the board with IPA.
  • Country: hk
« Reply #8 on: July 06, 2020, 10:06:20 am »
Received batch of Vishay Dale (VA) CRCW1206 1% resistor from Digi-key to replace those damaged by the leaking SMD capacitor and found they didn’t have value printed on top of  :wtf:
Wish me luck  :-BROKE
