Author Topic: LeCroy rotary encoder axle/shaft  (Read 919 times)
Offline spilihpsTopic starter
« on: July 09, 2018, 05:27:24 pm »
Hello!
Iam currently repairing a LeCroy 454, and it is missing a couple of rotary encoder axle/shafts(whatever it is called?)
The encoder itself is working fine.
Are these shafts avaiable somewere?
The knobs themselfs seems to be still available from lecroy.
Offline Stray Electron
Re: LeCroy rotary encoder axle/shaft
« Reply #1 on: July 09, 2018, 11:19:26 pm »
   On the LeCroy 94xx scopes, the shaft is part of the rotary encoder (made by Bournes) and neither part is available from leCroy. I haven't found the exact Bournes part anywhere but a similar model should work or you can probably take a new encoder apart and get the shaft. Or just get the right encoder from salvage. For knobs, I use knobs from some of the OLD Tektronix scopes.  They're red but who cares.
