Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Amp fuse
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Amp fuse (Read 1098 times)
nus
Contributor
Country:
Amp fuse
on:
August 22, 2018, 06:59:20 pm »
beta three ua 2000
got and old amp wanted to see if i could repair it, but it seem like the mains fuse is missing. cant seem to find the fuse rating in the manual. it says 220v 1500 va so would i be fine just thowing a 7amp 250 volt fuse in there.
Last Edit: August 22, 2018, 07:34:22 pm by nus
Logged
coromonadalix
Super Contributor
Country:
Re: Amp fuse
Reply #1 on:
August 22, 2018, 08:23:53 pm »
You could put an 7 or 7.5 amps slow blow, would be enough to take a few boom boom loll
1500va / 220 vac is 6.8 amps
Logged
mzacharias
Frequent Contributor
Country:
Re: Amp fuse
Reply #2 on:
August 23, 2018, 09:54:14 am »
DO NOT simply add the VA rating to get an appropriate fuse value. The value should be printed somewhere near the fuse, if not - post back here with a MAKE AND MODEL number and we can probably look it up.
Logged
coromonadalix
Super Contributor
Country:
Re: Amp fuse
Reply #3 on:
August 23, 2018, 10:54:20 am »
okay on some audiophiles websites you have an t20 slow blow fuse for 220 vac, t40 slow blow at 120vac is it enough ??
Way more than expected and deduced values in my previous post, this one puts tons of amplification wattage ...
Stereo w/ch 1000w x 2/8Ω - 1600w x 2/4Ω - Bridged mono 3200w/8Ω
This puppy has no fuses markings on the case ... ask the company to be really sure
http://www.livansud.com/index.php/audio-pro/potencias/beta-3/ua2000.html
Last Edit: August 23, 2018, 11:00:17 am by coromonadalix
Logged
mzacharias
Country:
Re: Amp fuse
Reply #4 on:
August 23, 2018, 11:47:07 am »
Apparently this is a very high power unit. Therefore I would suggest using ONLY a manufacturer recommended fuse.
I suggest ordering from the manufacturer or distributor. There are special safety considerations for very high power equipment.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Amp fuse
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
