Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
[SOLVED] Recommended QN7002 n-channel MOSFET alternative
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: [SOLVED] Recommended QN7002 n-channel MOSFET alternative (Read 3213 times)
cyferc
Newbie
Country:
on:
April 11, 2017, 01:53:04 pm »
I am a complete noob with hardware so I apologize in advance.
I have a damaged SOT-23 component in the voltage regulation area of my PC motherboard. It has the code "G28" and I figured it is a Renesas QN7002 N-channel vertical type MOSFET. I just looked up the code on
http://www.s-manuals.com/smd/g2
Here is the data sheet:
http://www.s-manuals.com/pdf/datasheet/q/n/qn7002_r1.0.0_renesas.pdf
I cannot seem to find that part anywhere so can someone recommend a readily available drop in replacement?
Thanks!
Last Edit: April 11, 2017, 06:40:11 pm by cyferc
Logged
rob77
Super Contributor
Country:
Re: Recommended QN7002 n-channel MOSFET alternative
Reply #1 on:
April 11, 2017, 02:21:01 pm »
2n7002 mosfet is jelly-bean part available from lot of manufacturers (ST, dioides incorp., fairchild... virtually anyone makes it) . so feel free to use any sot-23 mosfet which has the number 7002 in it's part number.
Logged
Ian.M
Super Contributor
Reply #2 on:
April 11, 2017, 02:22:24 pm »
http://www2.renesas.eu/_pdf/D18259EJ4V0PF00.PDF
gives some cross-references. It looks like its a re-packaged 2N7002. Caution SC-59 and SOT-23 package dimensions are *NOT* quite the same so check compatibility with the actual board footprint before ordering.
Logged
cyferc
Newbie
Country:
Reply #3 on:
April 11, 2017, 06:38:37 pm »
Very helpful, thank you very much!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
