This station has firmware updates available, I'd suggest you start there, maybe you'll get lucky and it'd fix it!
Regardless, I think you should've done some more research before purchasing because there's no practical reason to have support for 3 different handles (it's more of a sales gimmick) and a single person surely doesn't need a soldering station that can operate two handles at once (that's more suitable for professional use by 2 people in a repair shop that work in the same room). Also, out of the 3, the T210 has the least amount of power! The T245 handle is best.
